richardlee
- Aug 20, 2011
- 49
I just changed the impeller. I placed the shift/throttle lever into forward prior to pulling lower unit. When I put everything back together, I had to force the lever back into neutral. A slight bump on the lever shifted it back into forward. I was able to start the engine. I decided to adjust the cables. I have them disconnected but the motor is in forward. I didn't want to put too much pressure on the shift mechanism to force it back into neutral. Do I need to drop the lower unit again? I did move the shift/throttle level while the unit was off. I thought I had it back in the same position before putting on the lower unit. Thanks.
