1974 mercury 115 shifting/throttle cables
richardlee
I had disconnected the shifting/throttle cables when I had my motor pulled. After hooking them back up, the shifting cable moves but doesn't seem to put into gear. I heard a grinding noise, so I quit. The throttle cable doesn't move at all. I have tried to moved it by hand and everything seems to be locked up. Any help in adjusting is appreciated. Thanks.
Chris1956
Re: 1974 mercury 115 shifting/throttle cables
Disconnect cables from the motor and observe them when moving the throttle arm from neutral to forward. The shift cable will move first, followed by a longer movement from the throttle cable. I suspect you have inadvertently switched them.
richardlee
Thanks for your suggestion. I had marked one cable with tape so I would know how to hook them back up, but it took over a month before I had the motor remounted so I might have forgotten which cable went where.
