1974 starcraft 16 ft super sport
Yeonik
Re: 1974 starcraft 16 ft super sport
To note, I spied that sea ray on cl today ;)
anderso8623
Talked to jas, he mentioned that the rails would not fit. I'm picking up a 155,000 btu kerosene torpedo heater tomorrow, that should do the trick then we can get this rebuild on the way. Keep checking for updates.
anderso8623
Tare down starts tomorrow. Plywood on order. New pictures soon.
anderso8623
Notice the temp. I have my door open about 4 feet on my 2 car garage. the manual for the heater says it only needs to be open 3 inches. I just want it to be easy to get in and out when I need something. Outside temp....23 F...and its windy!
anderso8623
the tear down is going good. I am interested to see whats under the floor as the PO decided it would be a good idea to use the plywood's 8ft edge for the first half of the boat...the back end is nothing but a patch job on the starboard side. Drills battery is dead and I got a party to go to. ill see you all back here on Tuesday or latter tonight if I get back in time.
anderso8623
I only have this gear puller to get the steering wheel off. As you can see, the arms are not long enough to grab the wheel and I do not have a perfect circle to grab onto in the center.
dozerII
Loosen the nut in the center till it is flush with the end of the threads, cuz you have the dash off, step on the sides of it and pull on the wheel, have a helper give the center nut a good sharp straight wack with a hammer and it will pop right off.
classiccat
"Captain" + Starmada Splash Of The Year 2020
Game-on! demo is progressing nicely :thumb:
anderso8623
So I see people using gluvit (I think that is what you call it) for the rivets. In previous rebuilds, I have used coat-it. What do you guys suggest I use?
jasoutside
Either one will work, both are great stuff.
Hey, I just pulled out a pair of bow rails donated from Thumper the Baja, I think those might work on yur rig:thumb:
They are kinda straight though.
anderso8623
They dont quite have the contour of my bow and I have nothing to bend rails. Thanks though.
Also, Can I use the coat it for the transom and floor as well? Or should I go with standard epoxy?
jasoutside
Yah, you are way better off running Epoxy for your deck and transom.
anderso8623
I plan to polish the hull, a few questions to get started:
1) What should I use to polish it? (i.e. type of polish)
2) How should the polish be applied?
3) What do I use to clear coat the hull after it is polished?
4) Best way to apply clear coat? I do have a sprayer but it uses compressed air and I will probably be doing this in a garage.
Any other tips on this process would be great!
Jason
jbcurt00
Don't clear an aluminum boat after it's polished. Use Shark Hid or a similar protectant. Quite a few have used it & to be best of my knowledge, none have any complaints.
You do need to keep the hull clean, and occasionally reapply the Shark Hid. I think InMotion left his Jupiter in the water for almost 4months, the Shark Hid didn't need to be reapplied, and the hull cleaned up really well.
Depending on the condition of the hull, how you strip the paint & if you want a HIGH mirror finish, just shiny or flat. That choice is often dictated by the hull's condition once stripped.
If you abraid the hull sanding off the paint or scratch it using a wire brush to detail the paint off around the rivet heads, it will take A LOT more work to get a mirror like finish. And significantly more time.
No matter how you choose to get the paint off, I'd start w/ the least aggressive means of paint removal & work toward harsher, more abrasive methods. Taking an extra day or 2 to get the paint off, could save you several weeks of sanding out any extra scratches & swirl marks you cause.
InMotion has been using an environmentally safe paint stripper that works AMAZINGLY well. Unfortunately he's in Canada & we can't find a source in the states or even a very similar US equivalent. Still working on that. How close are you to the border & do you ever head north for business or pleasure? If so you might try to find a Home Hardware store where ever you are in Canada. Look for this stripper:
Safe Strip by Nutura:
InMotions video about using it:
Using plastic scrappers & brushes, he's almost down to a high mirror finish in 1 application & removal of the stripper. He'll give you brief details on the other paint removal methods & then how well the Safe Strip works plus a time line for using the stripper.
anderso8623
I have been following the videos he has been posting and safe strip is what has inspired me to go with the polished look. I suggested we do a "rum runner' style bootleg. I’m kidding of course. However, there is one in Windsor, basically right where the tunnel comes out. I was planning on taking a trip but I am trying to figure out the rules for bringing chemicals across the boarder.
jbcurt00
When you do, post the info. There's a barrel full* of Starmadian's in Michigan, I suspect more will dare to go bare if they can get similar results to IM's w/ so little effort.
* Actually, so close to the motherland, there's probably a truck load of full barrels worth of 'em.
