1974 Starcraft Chieftain
jbcurt00
Re: 1974 Starcraft Chieftain
Thanks, everyones doing great.
I getting antsy to get this boat seaworthy and some more of the old Mercs restored.
Is it too early for Andrew's 1st impeller? NEW it'd kinda sorta be a safe teething ring, right?
I need to drag a running 1969-71 65hp Merc out of the back of my storage/shop space at work & give it some much needed attention as well.......
bgc
Ensign
I like this idea! One of the giant Volvo impellers should work....:)
I have a 1965, 65hp in the collection, Damn things are heavy! Took two us us to hang it on the rack for the winter
Cloudrnnr
Holy Smokes! You risked buying a boat, without the Admiral's authorization...while she was pregnant? I'm thinking the new name is obvious..."Constant Peril"
Congrats on the new additions!
bgc
Ensign
Yes, I did and she still doesn't know about her and Thank You!........ Do you think the name would be too pretentious and anger the gods? How about "DogHouse"? :joyous:
bgc
Ensign
Alright! Getting back into it, going to be a slow process till new First Mate can work a saws-all......
After seeing WW's progress on his Chief, I have ordered the paint. I went with an Acrylic Urethane in White and a Clear topcoat.
The engine is scheduled to go into the Machine Shop later this month
jbcurt00
I've been doing a good job hiding it so far....but the pier pressure is getting to me.
Good luck.
A finned 15-16ft tinny popped up @Cleveland over the weekend, but I figured you're hidden tin quota might already be full :cool:
bgc
Ensign
Good luck.
Yeah....no more boats, although I've said that before....
Watermann
It will be interesting to see how the lacquer clear coat goes on over the acrylic paint.
bgc
Ensign
Clear Acrylic Urethane..... I figure if i get enough paint on the hull it wont leak..:laugh:
Watermann
Can you use the catalyst hardener in the clear too?
GA_Boater
Good point, bgc. :)
Good question - I've been wondering a while. Hardener should also help improve leakability too. :joyous:
Watermann
Oh man, is that 228 dollars? ... as in semolians, green backs? For Rustoleum? A gallon??? :eek: :faint2:
jbcurt00
Yikes man, I have less in a whole boat motor & trailer then 1 gallon of that paint :faint2:
Hides a big ole boat from the Admiral, but can swing $230/gal paint... Brave or ???
