1974 starcraft islander overhaul
dproctor1
If you can't get the exact measurements from anyone, might try the following. Figure out the aluminum transom size and then cut off 1/2 - 3/4" at each side. Might be able to do a cardboard cutout as well.
SHSU
To me it looks like the transom has pulled in a bit im just curious what the width is the transom aluminum is bowed out at the top a bit
dproctor1
This is what I'm talking about the bow in the transom
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
So I had some of that in mine, and attributed it to stretching from the bad transom and motor bouncing. Since yours is an I/O not the same, but not sure if any starcraft was perfectly flat even from factory.
SHSU
Watermann
I see, the bowed out transom skin is not a concern, the transom wood doesn't "stretch" from the sides as the wood doesn't even touch the sides.
Take a look at the transom skin on my Chief with the old rotten wood still there it was bowed too, real bad after the fasteners and cap were removed. It'll all suck back together just fine.
y4mp2NgamKwfspYsXuCUHn3fH5q8BgiB6gmej-3SqK61bU2zVMXl3ME4V4C-r6XWdeSStJILq9605w1aM2-pMG5yTI9uDUejS5qQxFFhhV-mqWYWCk7_WZUs1eIhw6D9ewSCCs70zpKsamY4kCRYNhDxwnrwdVfqm91Xwi4t1T1ZKJqJeJr7m6iv6oCpku3t-1K
The John
If you are going to change your transom, I would highly suggest taking ideas from whats called an Offshore Bracket. Out in the PNW a lot of the new boats are built this way, it leaves a bunch of room for storage/kill boxes/fish coolers/etc. Check out the attached picture, I am sitting on top of one.
dproctor1
Good to know I just thought it pulled in on me when I took it apart hopefully get some more work done on it this weekend
dproctor1
No work on boat its -17 but I sold the motors and stern drive and acquired more tackle for salmon/ walleye
dingbat
Hope you don’t need any parts for those reels...they don’t exist. Worst parts support in the industry
dproctor1
All I run is okumas and never had issues with them.
On a side note got some conduit for my wiring to run through.
SHSU
Any idea how many wires you plan on running through your conduit?
SHSU
SHSU
Power wires for a fuse block transducer wires and some wires for the engine
Ah, so nothing major. Makes sense. I went way overboard on my wire runs.....
SHSU
dproctor1
Yea I dont want to have a pile of wires thats why I figured I'd use a fuse block keep it clean
dproctor1
Got a bit done cut some stuff up and sent to a welder hopefully have it for next weekend made up my support for my kicker bracing should work alright
dproctor1
Anybody have a measurement or rough idea on the height of there outboard bracket thats put one on and what length of shaft motor was used
Thanks
SHSU
Thanks
Bracket would depend on the shaft length of your motor. General sizes are:
Short Shaft: 15
Long Shaft: 20
X- Long Shaft: 25
Measurement is from top of transom to top of the ventilation plate. Ventilation plate being in line with lowest point of stern. That should give you a fair idea on bracket placement.
SHSU
sidingguy
Most bracketed boats run a 25" shaft outboard to keep the motor out of the water at rest.Do some research, there is a formula they use for length of bracket to height on the transom,My 19v islander has a 25" shaft OMC outboard on a Seadrive bracket from Starcraft.
dproctor1
I've been looking online looks like general rule of thumb for brackets is 1" of height per ft of setback on the bracket
Looks like a great project! I'm in the rebuilding phase of my 1984 Islander i/o to outboard bracket conversion. I really like your idea of putting the solid strapping / bracing across the stringers. That will really lock everything together and give great support to your floor. What thickness of aluminum are you putting down on the floor? I'm going with .125 for mine. Are you going to do sheet foam or pour in foam for flotation? After taking out close to 900# of waterlogged pour in foam, I'm going with sheet foam.
