1975 70hp johnson going into gear
fireplug
my problem is the engine will crank and run fine but when you go to put it in gear the engine dies. when you put it in gear out of water it goes in just fine, forward and reverse.i tried idling it up and it still dies. im afraid to go any further on idle speed because it might damage something.any help will be greatly appeciated.
wikelam
Re: 1975 70hp johnson going into gear
try the evinrude johnson forum
Mod2
Moving to Johnson/Evinrude Troubles/Repair forum.
The Marine Doctor
Please check your compression and spark and get back to us.<br /><br />TMD
fireplug
i checked the compression and its good and i also checked the spark and its getting good spark. it only dies when its going into gear in the water other than that it runs great.
