Re: 1975 Chrysler 459he 45 hp running issue
Seals should be reasonable to do. Attachments are at the address below (not far down) showing my challenge and success. I tried to spot Frank?s tip on pulling the Etc after the two bolts were removed. I?m almost sure it was not with a puller. Maybe, just lightly worked off, since the O-ring seal is the drag/resistance (once the bolts are removed). Getting it started after bolted for years might gave been the issue but it came off and I replaced an O-ring and seal to solve the leak.
The search is a powerful tool for past info but a little time consuming and saving. Good Luck, I?m Out of Time But Will Check Back!!
http://forums.iboats.com/force-chrysler-outboards/1974-chrysler-35hp-water-pump-question-402338.html
