flyingscott
- Apr 8, 2014
- 8,248
Lean Fuel Mixture
A common cause of overheated pistons relates to insufficient fuel delivery to the cylinder to keep the temperature down. Idle mixture screws that have settings which are too lean will cause a lean air/fuel mixture, and too much air in the combustion chamber causes the temperature to rise. Kinked fuel lines and clogged fuel filters will also starve the cylinders. A rich, or wetter mixture counteracts the condition.
https://itstillruns.com/causes-up-pi...r-8669199.html
This article was written by the It Still Runs team, copy edited and fact checked through a multi-point auditing system, in efforts to ensure our readers only receive the best information
Truth is you dont know your a** from a hole in the ground bud
How.does the.low speed adjustment cause a lean condition that will damage the motor? The.low speed adjustment has absolutely no effect on high speed operation. The only thing that can cause a lean condition at high speed a plugged main jet. You cannot run a.outboard lean at an idle to cause damage. There is just not enough heat created to at around idle.speeds. You may want to look at how your carb actually works.
