Re: 1976 25 hp Points question
I'd suggest that while waiting on the parts you need , perform a decarb on the engine especially the wot while on the boat. After installing the new parts and getting the motor up to operating temps while on the water and pushing the boat, then set the idle/low speed mixture. I've been working on a 71 Sportster and it really doesn't respond well to setting the idle/mixture in the barrel as it inhales a "lot" of exhaust. The decarb should result in a more "tuneable" engine.Also, at idle, do you observe any armature plate play?..Seems to be common on these and mine moves back and forth about 4 degs. at idle. Not a lot, but doesn't help any in setting the idle.
