1976 35r76g s#e4599657 intermittent spark both plugs and no fuel to #2 cylinder
Jell-O
I think 1976 Ignition coils have some cracking the ohm readings are 1.7 on my 200 scale meter no fuel to the bottom cylinder but I got to have spark first I've reset the points one was never opening looks knew condensers don't show shorted when i got flywheel everything was pristine the coils still had green paint on the pick ups ive pulled everthing off the top looking for a short ive bypassed the kill sw. It will spark both at times it sux getting old and loosing your edge if anybody can give pointers I would appreciate it
Crosbyman
The paint should never wear off the coils.-----No fuel to the bottom cylinder means an issue with reed valves or bottom crankshaft seal is bad.
Jell-O
I've never seen paint on the pick ups the part that riding against the inside of flywheel not ignition coils
there is no need for anything to rub inside the flywheel.----And why was the comment about paint on the pick-ups made ??
Jell-O
Yes it was green paint from factory it's all green except for the coils but I did sand the paint off the pick up now I have new ignition coils and set the points got great spark and fuel to the plugs their wet but it want hit a lick I'm lost now... again I bought coils that was initially my problem this motor been sitting for years when I bought it thanks for your help
Jell-O
Ok racer it must have been when the shear pin sheared I've got it all back together ingnition coils was the problem got fuel and spark and nothing could it be the timing since the keeper sheared on the flywheel? I have no clue at this point
Jell-O
VOM "short" test on condensers is unfortunately not conclusive when it is " good" you realy need to load test them at high voltage... if never replaced try new ones or swap parts to see if the issue migrates.
point contacts must be clean clean clean !!!
Thanks Admiral but I have no clue how to download the information you sent I changed my ingnition coils took the points out sanded everything back together had great spark and fuel my flywheel broke the woodruff key month ago and I got one at hardware store with a little and I know better hey i would like to thank you for your concern and support its not right need a another flywheel I've checked eBay TBN it sux getting old anyway thank you Admiral I'll take all the info you can give beware this is just one motor 5 years ago I would not have to ask for help
Jell-O
Hey racer thank you for your concern and support that means a lot to me I got excellent spark and fuel but now I need a flywheel 35r76g and again ty jellybean
