wow thats some insane wind,hope everyones ok
That would have been a tough day on the water. Almost a hurricane - Yikes!
Up here on the prairies it blows lot's and hard at times we are pretty much used to it. Lots of tractor trailer units get blown over west of Lethbridge during these real bad winds, but the wind tends to slow down a little by the time it gets to us. I don't go near the lake when she's blowing like that.
The weather has said it's time to start fixing this boat!!!!
The out/drive is off and the tear down has begun. It's amazing what you find when you get into things. I can't believe how well this boat worked considering what I have already found. The shift cable was completely corroded through to the inner piece next to where it screws into the bell housing, there were only about three strands that kept it working. The o-ring that seals the upper housing water passage to the motor was split, the hose that carries the water to the motor was covered with cracks and loose at the top and obviously leaking. I will post some photos when I get back from the Thanks Giving long weekend Tuesday.
Yikes!!! Yup, what appears on the surface to be minor is often much, much worse once you get into it... looking forward to seeing those pics!!!
Have a great Thanksgiving there Glen! And a shout out to all fello Canuker's... Happy Thanksgiving!!!
Jim
Wough, yah man, she's due for some repair. :blue:
Looks like she missed a few annual maintenance procedures. Most of them from the looks. Was she laid up for long time?
Dozer - Did you ever find affordable screws/bolts for the loose steering problem?
Yikes! Glad you weren't driving when the cable let loose! Good decision to start the tear down... worth it for sure!
Interesting that the transom was in decent shape... how is the motor? It looks relatively clean from what I can see...
Jim
The new owner of the 201 is coming this weekend to pick her up
Sad and happy all rolled into one. The 201 goes to a new home :blue:, the hangar gains work room :joyous:. 80 bucks - Shipping rates up in the Northland are as high as the Northern Lights.![]()
Yikes, kinda sad right there eh? Give her a big hug for me before you send her off ok?:wave:
+ 1 on GA's comments and Mr Jas.... It's sad to see that one go.... but a new restore awaits some of your Tin TLC...!![]()
Hard to believe you'd be short on space in that big ole hanger... but with 2 boats in there, I can see how that might be an issue!
Too bad about the parts there... not brilliant service to say the least. Hmmmm... hopefully it gets better from here.
Jim
