I am looking for some help/advice on rebuilding/upgrading a 1976 Johnson 115. I will break this up into sections for better understanding. I also do not know a lot about boats, so sorry if anything is stated wrong.
1. What I know/don't know.
I do not know what model the engine is or where to find it. I am pretty sure it has been in AZ its whole life, so just fresh water, no freezing temperatures, and a relatively dry climate, aside from when it was on the water. It had the heads pulled off probably about 20-30 years ago, but nothing else. It was running at the time but allegedly was bogging down. It is clean inside the cylinders, and the whole engine for that matter. (given its age, it has a bit of dust and oil, but looks great otherwise)
2. What needs doing
At the very least it needs head gaskets. (I don't know what gaskets to get because I don't know the engine model, if they are different from one 115 to another in the same year) I probably have to replace all the fuel lines because I am sure they are not good anymore. And to solve the bogging down issue, I think new plugs, and a carburetor rebuild. (correct me if I am wrong).
3. What I would like done
A. It would be nice to get a bit more power out of the engine, but I do not know how that can be accomplished specifically. Can the cylinders be bored out safely, and if so how much, what pistons and/or rings would be needed, and how much difference would it make? What about a carburetor upgrade? I am not sure if there would be anything else that can be upgraded within reason, or if it would make a noticeable difference.
B. It would also be nice to get a bit better fuel economy out of it if possible. I hear as it is it is/was not very good. I would plan on skiing with it, so don't know if both power and fuel economy are possible, or if that is a propeller issue.
Summed up, what head gaskets do I need? Are there any ways to increase performance and/or fuel economy. Is there anything I should look at/replace on the engine aside from fuel lines and the gear oil?
Thank you to anyone that can help.
Edit. I added some pictures of the engine, and I added some oil in the cylinders to avoid rust. And yes, I do know there is a little bit of junk in the cylinders, and I will clean it out before running the engine.
2. What needs doing
