Well, as this is my first post, i'll give some background information on myself.
I am have been an auto tech for a few years, however I have not worked around boat motors. I am a technical and qualified person to fix my own stuff, but I also enjoy learning new things. So if you dont think I will know something, please take the opportunity to teach me!
First off, its a 1976 Johnson 25HP, pull start, short shaft 2 stroke.
The boat starts great (1 or 2 pulls max). I had the carb rebuilt chasing this problem, without really doing any diagnostic work (has not had it done in quite some time, I figured it couldnt hurt). The Motor also runs well at WOT. However when you are idling to park at a dock or something the motor will cutt of. It will misfire once or twice, and shut off. It will do this any time I bring it down to a low idle, hot or cold.
The next problem is when I accelerate. If I am at a slow speed (4 MPH maybe) and give it full throttle, it will accelerate really roughly like it has a dead cyl or something (motor shakes back and fourth as it accelerates). However one at WOT everything seems to clear up, or if I back off the throttle (reduce the load) it will clear up.
In the automotive world this would indicate some sort of secondary ignition problem. However i dont know if this carries over to boat motor world. Another question I have is how many coils are on this boat motor? I have seen other threads that indicates a coil under the flywheel. However my motor has 2 coils right next to each spark plug. How do the 3 coils work on this system? Why 3? Or do I have a newer ignition system and no coil under the flywheel?
Also when I am turning the boat it neutrals out (revs high, motor seems to stop propelling the boat). I had always though this was due to some sort of cavitation near the prop, and it just hitting air in a turn, however is it possible that the actual cause is some sort of issue in the geartrain? If it is cavitation, how can I reduce it? Or is this some sort of issue with the lower unit? It only does it in a turn.
Thanks for any and all help you give,
-Pete
-Pete
