1976 mercury 40hp flywheel question
Should there be any play where the flywheel bolts to the crank?
  • 71849216883__194D3A14-F256-4940-9110-ACC8B6584207.MOV
QBhoy
Doesn’t look good there. Is there a damper on that at all ? I’d disable the ignition and take the plugs out…then put it in gear..have someone turn the prop shaft whilst you check up there. See if any backlash is taken up some or otherwise
Chris1956
Make sure the ring of small bolts around the large flywheel bolt are tight. Sometimes they need Loctite to stay that way.
Maybe the flexplate is broken.-----Post pictures or video in an easy for me format.
jimmbo
Could be a Pooched Upper Bearing, but in any case the Crankcase is gonna need to be split to see what is going on in there
