gm280
- Jun 26, 2011
- 14,605
With the job your doing on the stringers the deck's gunna be a piece a cake !
A lot more fun after the grinding is done huh !!![]()
aphelps, the really tricky part about doing this boat, but probably any boat for that matter, is trying to get the stringers in straight and level from all angles. I mean this is truly three dimensional efforts on a tri-hull boat. And the only thing I have to work with is the rub rail along the top to get my measurement from to get everything installed properly. That is why I haven't remove that rub rail to finish off the CSM hull overlay around the top yet. I did take measurement before I removed anything and seems like the top rail is my reference to work from. So I am trying my best to install the floor level and straight as I can get it. But then I have to make certain that anybody I take with me fishing won't punch through the flooring either. My two adult sons are pretty big guys! That is why I decided to mount ribs, I mean bulkheads every 24" to help handle the stress on the flooring. But given that I will also use mix and pour foam should help a lot too... This building brings back my airplane building days. Very similar indeed. But I am loving it seeing how everything is fitting together now. I have to dream up unique ideas to cut the parts out to make sure they are correct. Thanks for the comment and looking at the updates. Comments and replies do keep projects going, that for sure!
