Re: 1977 25hp Johnson Opinions
Use sealer on the exhaust cover gaskets.
Did you hone those cylinders and replace the pistons and rings? If not, it really doesn't much matter what you do from this point forward.
The pistons on a two stroke act as VALVES. The piston skirt seals the area between the exhaust ports and the crankcase (where the intake is). A lousy fit or scratch marks allow air/exhaust to bypass back and forth from intake to exhaust and back. If you put those junk parts back in there you will get what you built.
