Re: 1977 Evinrude 115 Runs Rough At Idle
That's okay, the headline says 1977, so you're good.
My suspicions exactly, you have differences in your compression readings. This is a large contributor to the rough idle. I don't know if decarboning will do anything for it, but it's worth a shot.
Any motor that's been in use recently, should have the rings loosened up plenty good. If there is any sticking rings, it's likely because of piston scoring around the ring grooves. Decarbing an engine is what you need to do for an engine that has sat for years, but I usually do this, with a little extra heavy mix.
I can verify this, because I have a 53 year old 18hp in my shed right now, that was stuck when I got it, but now runs like a clock. I even found rusted out spark plugs when I got it home. A little WD-40 and running it, everything is flushed out and cleaned up. LOL Main thing is, the pistons are not scored and I have over 100 psi per hole.
The V-4 models were notorious for reed valve problems and scoring pistons, dating back to 1958. The old 50's and 75's had reed valves that were extremely fragile and were prone to failure. I think if you pulled the bypass covers off and looked through the ports, you can get a good visual of the pistons and see if there is any scoring. The intake side is where the particals typically enter and creat issues. The exhaust side is the side that gets hotter but the particals are already burned. It's been said that 50:1 is okay on these, but I think more like 32:1 is better on the V-4 units. This is because I see a lot of problems with uneven compression. The bigger motors like the V-4's and V-6's....V8's included, are more of a performance engine. I have a 25 that was designed to run on 100:1, but it was quickly discovered that "that don't work" Many motors like it were recalled and the owners got free rebuilds. My old 18 was designed to run on 24:1 and that is probably why it has held together for 53 years even after being stuck and water in the cylinders.
It's possible you may need an overhaul, but I would explore the free checks first.
Fouled plugs should be tossed and replaced with new ones.
Ignition systems should be kept in clean operating order
An engine that runs at high rpms more than low, should be a little rich on the oil mix. A typical fishing engine that usually spends it's time trolling is good at 50:1, but these big motors that pull a lot of wakes and skiers......well....I would richen it up a bit. A fouled plug is better than a scored piston.
