Re: 1977 Evinrude 140 Stalls in gear (runs in neutral)
I wonder if you would elaborate on the following a bit:
"BUT, like I said in the beginning, there's the occasional "puff" that comes out of the exhaust from the top right cylinder, apparently indicating that it works about once a second. When I take that plug off, the puff goes away."
Specifically, what exhaust are you speaking of when you say "...comes out of the exhaust..."?
About the compression: the piston rises past both exhaust and scavenger ports, pressurizing the fuel that it has scavenged. The tighter the piston and rings, the better the compression. The compression gauge has a valve to keep the air from escaping so that you can take a reading before releasing it. Therefore, the compression is independent of what is taking place behind the piston.
Bill Kelly explains 2 bangers pretty well: http://www.maxrules.com/fixtheory2.html
