1977 Glastron Sportster Restoration
Ezramacc
The transom is built and installed . I already tore out the old stringers . THEy we’re so rotted I couldnt use them to trace. How should I cut and install my new stringers and what type of wood should I use ?
Woodonglass
Use the same plywood you used for the transom. Run a Stringline both Stem to stern and Port to Starboard at the deck level then use cardboard and a Compass to scribe the hull line to the cardboard. Measure from the string lines down to the hull to establish dimensions every 3-4 inches.
