1977 Johnson 35 HP 35EL77H-Rectifier and starting battery recommendation?
jitterbug127
There would be three capped off wires somewhere....pretty sure you do not have one.
That’s my thinking as well.
Did find out the 15 hp I have in the shed used all the same parts numbers. That might be worth swapping over to the 35
cyclops222
Another motor with a part sold off of it.
I looked up your exact motor. Rectifier & terminal strip are STANDARD parts.
$ 58 and $ 11. Still available.
jitterbug127
The rectifier and bar are not the expensive parts. It’s the charging coil. Look at those prices 😳
