1977 omc stringer electric shift TRIM/TILT PROBLEM
markboutros
hey folks,
My trim/tilt has been giving me problems, I changed the motor last year so i know its not the motor....It will always go down but some time when I try triming up it wont work, all i hear is the siloniod clicking.
After i run the boat and bang it around the lake for a while it will start working again.
I think its the siloniod. It looks old as ****
What are your thoughts??
Redrig
Master Chief Petty Officer
Re: 1977 omc stringer electric shift TRIM/TILT PROBLEM
mine was doing the same thing. next time the sileniod clicks go back there and just jumper accross the sileniod with a short stout wire. that should tell you if the sileniod is bad or not.
but either way, probably a good idea to replace them if they are old as ****
markboutros
which terminals do I touch together??
Redrig
One of the terminals will always be hot with the key on.
with a multimeter find out which one gets hot when you tilt up, then jump to that one.
dont quote me on this as it has been a while. but on MY boat the tilt up sileniod is on the starboard side, and the side that i was jumping to was the inward terminal, or towards the port side. Good luck
markboutros
so basically i will touch the jumper to the power (which will be the red cable) to one of the 2 terninals (one terminal should be trim up and 1 terninal should be trim down) the 4 terminal is ground (with a black cable coming out of it)
Do i have that correct.
southkogs
...but either way, probably a good idea to replace them if they are old as ****
Agree with RED ... those solenoids are also cheap as ________ .
Do a quick check that your trunions are greased and that your clutch pack isn't all gunked up.
Redrig
No, you have a total of 3 siloniods towards the rear of your engine.
1 for cranking / starting
1 for tilt up
and 1 for tilt down
the tilt ones are located directly behind the engine under 2 large looms of wires, the cranking one *should* be more off to the starboard side, mines is anyways,Its the one that is connected to the starter.
I have a ford, so that is what I am reffering to. I dont know what you have, a Chevy may be quite different.
markboutros
That makes scence cuz the solinoid right next to it for trim down looks brand new.
I will just replace that solinoid and call it a day
Thanks for all your help.
Redrig
good call.
be sure to follow southkogs advice as well and make sure that everything is moving freely and lubed up.
Howard Sterndrive
btw, that isn't power trim
it is only tilt for trailering
markboutros
I was out there yesterday and it was working just fine, Ill probably wait till next summer to chance it out.
Thanks for all your help folks
Happy boating!!!
