1978 115hp mercury shift problem
Elliomcmh
Hi, my engine will not go in reverse when shifted from the controls. I can undo the linkage and it will shift fine, from F N R, when manually shifting the shift rod. But when I hook the linkage up, even though the shift rod is hitting the same point, for some reason it will not even come close to going into reverse. Any ideas? Thanks
Re: 1978 115hp mercury shift problem
Maybe you have a bad control, or the cable is not adjusted correctly. Release the cable from the clamp on the motor. Now set the control to neutral and set the motor manually to neutral. See if the cable will easily go into the clamp. If not adjust the barell nut until it fits the clamp easily. If that is not it, you might take the control box apart and look for broken/work parts.
Elliomcmh
I'm about to give it a shot, thanks for your help
CharlieB
How OLD is that shift cable?
An old stretched cable will give you those same problems, readjusting may not solve the problem, a replacement cable is necessary. A new cable is cheaper than the cost of rebuilding a gearbox because the worn cable will continue to accelerate wear on the engagement dogs by not shifting firmly and completely into gear.
Elliomcmh
The cable has a date of 02' on it. I did unhook all of the linkage, and figured out that when manually shifting the shift rod from neutral to reverse(engine off), that it only engages when the prop is in certain positions. When the engine is running, and I try to manually shift it into reverse, it goes in every time. But never with the linkage hooked up Thank you for your help
merc850
"Due to the design of the shift mechanism the motor should only be shifted into reverse while running or you can damage the shifter" - it says in the manual.
Elliomcmh
Ok thanks for that very important info merc850, I'm definitely glad that I know that now, that sheds a little light on things.
Elliomcmh
What's the best way to figure out what size/model shift cable? And, can anyone recommend a website to order one?
Mercury control cables are avail at most marine stores. Find the number on the cable to get the length, or go on the Teleflex website and find the formula to determine the length of the cable needed.
Are you sure it is a cable issue?
Elliomcmh
I think that's what it is. Several people recommended that I try that first. Is the control mechanism hard to take apart? Do you have any other suggestions what my problem could be, if it's not the cable?
I have never had a stretched cable. I cannot understand how that would be an issue. Why not measure the travel the cable goes from neutral to forward and from neutral to reverse and see if they are the same. If not, it is likely a control box problem.
The bod comes apart with two screws. it is a bit complicated, so take your time.
Elliomcmh
I am going to measure it. I do know that when the controls are in the reverse position, the linkage is all the way to the rear, and the shift rod is in the correct position to shift the motor into reverse, because I can manually shift the engine into reverse in this same position with the linkage undone and the engine running.
It is possible the upper and lower shift rod are out of alignment, as they can fit together several ways. When the motor is in neutral , the shift slide should be in the middle of it's travel.
