I have a 1978 85 HP Mod # 85899C. I am replacing the Head gaskets, head cover gaskets, and both exhaust cover gaskets, plus a new water pump and new screens by the water inlet. I have a Evinrude service manual but need to know the torque specs for the bolts on the head covers,exhaust cover and bolts to the lower unit. I forgot to mention I'm also putting new thermostats in it. This motor has been setting for a few years and when I started it it ran fine but was leaking water around the gaskets I mentioned. The cylinder walls look great and the sides of the pistons (that I could see with the exhaust cover off) look great also. The rings appear to be free also. The inside of the motor is clean with very little carbon build up on the tops of the pistons. Another question I have is the head gasket was only available thru a dealer. NAPA did not even list the 85 HP for this year for a head gasket. I got the first set of gaskets I ordered and they were the wrong part number but were nearly identical and $16.75 each. I took them back and got the ones it called for Part # 318662 and they were $46.75 each. Is there something special about this year with the head gaskets? What a shock when I went to get them babies. Thanks for any info.
