Hi I own two 78 105hp chrysler motors one on a fin and fun the other on my most recent retoration a conqueror with same motor.
The fin and fun worked great until it had a bolt co e lose on the roller and went through block. The conqueror was short only a starter so I swapped it from boat 1 as well as the carbs and replace all fuel lines and spark plugs and re did all wire ends and clips and have double checked all connections. I have good compression but have no spark. I swapped out the wires and stator from the fin and fun which I know worked butnstill no spark. Only thing I havent changed is my fin and fun had a rectangle white box on the stator with a long fuse looking item inside of it that was tied in to the ignition spot and the other lead going to the negative on the stator. The conqueror just has a cylinder shaped item with one black lead going to the negative of the stator. Not sure if this could be my issue or if the part the wires attach to that has the shaft that goes up to a belt to the main shaft needs to be replaced. If this makes any sense pleaee help lol. Im trying to get this boat back in operable condition and im kind of at a loss. Been reading on updated conversions but not sure if I can do it for my motor or how.
