1978 Evinrude 70HP- Trouble starting/idling/bogging under load
evinrude2323
"wet plugs" "starts and dies" "black fluid running from lower"
Spark jump test....buy a cheap one, $15 at any auto parts store or get a nice one online.
Could be one of many electrical issues. Rule out each thing and move on.
Once running, take it out on the water and magically watch the sludge go away.
So you are leaning toward it being an electrical isssue?
I clearly indicated to you that there are no timing issues !!----There is no belt.----There are no valves.
saltchuckmatt
Muffs are for flushing mainly or doing small adjustments at or near idle...
I would not tear down the engine until you check for good spark.
tphoyt
It wouldn’t hurt to take a peek at the fuel pump as well. Kits are cheap and if it’s the original it’s probably due to be refreshed anyway.
A leaking diaphragm will add extra fuel directly to the cylinder adding more fuel than needed.
Could result in one plug being more wet than others and to the black crud your seeing from the exhaust. If you can get it into a trash can instead of the muffs. It makes a difference.
Jmo
evinrude2323
Jmo
I will get it into a trash can 100%. I also think that this engine just needs some love and new parts. I found a video that I will link in this message that I am going to use as a guide. I likely wont rework the heads, but after seeing this video I would love to get the head off and check the pistons and cylinder walls. And I agree the fuel pump is definitely getting an inspection and new diaphragm.
Thanks for all the help everyone! I'll keep posting and get some pictures of it up.
tphoyt
Pulling the head is well worth the effort.
If for nothing else you have inspection notes for future reference.
Resurfacing the head is easy and would be worth the time spent.
evinrude2323
Agreed. I will get it pulled and throw a new head gasket and get eyes on the condition of the inside.
evinrude2323
evinrude2323
Does that need to remain open always? And why or how did that switch get flipped? It didn’t big when I gave it a little gas either. Wow I really can’t believe it if that is the issue. Guy I bought it from said it just happened to him out of the blue so he sold it for super cheap. It feels too good to be true… like there might be something else
