1978 Johnson 115hp Bad Ring - worth messing with?
Okay, above mentioned outboard started idling rough/dropping a cylinder. had to adjust the idle up a little to keep her cranked.
did compression check
1,2,4 cylinders all 125-130psi
#3 cylinder 100psi.
Opened head and noticed very small imperfection where a ring is starting to sheer. cylinder walls are beautiful, no grooves or scoring, no noticable wear.
my question is: IS THIS WORTH REBUILDING THE MOTOR?
my second question is: HOW LONG CAN I RUN THIS MOTOR BEFORE LOSING THE CYLINDER COMPLETELY?
keep in mind, this tank of a motor does not have tilt/trim. is it worth buying a used tilt/trim (found one for $300)?
should i just sink extra money into repowering with a newer motor? when i say new, i mean one about 20 years old instead of 34 years old.
boobie
Re: 1978 Johnson 115hp Bad Ring - worth messing with?
It won't run to long with the shape it's in. Your choice, either rebuild or a different mtr.
Sh*t thats what I was scared of. I don't think I have the Mechanical Ability to Rebuild a motor. I understand BASIC principles of outboards, but the Thought of pressing rings and all that is daunting. can an average joe do this kind of thing?
emdsapmgr
If you consider yourself handy and can read a service manual, you should be able to tackle the project. You'll need a factory service manual-don't settle for anything less. Check out: outboardbooks.com The concern for still running it is that if the ring goes, it could damage the cyl walls-possibly requiring an overbore. As is, you might be lucky and just need to hone it and put in new rings.
thanks. ill kick around the idea of rebuilding. might just try to find another powerhead. then i can rebuild at my leisure. jury is still out. thanks again.
okay, so I wussed out and put it and my 2 parts motors on craigslist. Gonna try to find something with good compression. Bolt on parts are one thing, but I know when I am biting off more than I can chew sometimes.
