Gauge is brand new. It is the Harbor Freight one thoShould be reading about 140 PSI.----So step #1 is a test with another gauge.
Test with another gauge.----Or if gauge is good you have serious piston / ring problems
Also I've read after compression check, to spray wd40 in cylinders and test again. Is that something, I should also do?Test with another gauge.----Or if gauge is good you have serious piston / ring problems.
Squirting any kind of oil into the cylinders is cheating. Hiding the truthAlso I've read after compression check, to spray wd40 in cylinders and test again. Is that something, I should also do?
I'll return gauge and get a loaner from auto parts store.Squirting any kind of oil into the cylinders is cheating. Hiding the truth
