jitterbug127
- Feb 6, 2023
- 665
I've got a 25 Hp and a 35 HP motor I can throw on it to try. The bow rising thing has made me too nervous to try up to this point.
Yes I can do the portable tach. I've got one somewhere here at the house, and I'll dig it out of a box.Looks like your motor could be tilted out a little more but not bad. From the look of the waterline you have a lot of weight in the stern. Check the pitch on your prop, probably will need to use less pitch to let the engine build up RPM. Anyway to add a portable tach onto your motor ? It needs to run at peak rpm at wot to get the most from your engine.
Boat looks good there, but look at the weight being distributed with all those on board ! Spread out your weight by moving some further forward. Gonna need to experiment where it needs to be. Depending on how many people you have in the boat, you may need to shift weight each time you go out.Here is the boat in the pond.
