1978 Merc 1400 Trim Rams
sYnOnYx
Hey Guys!
Well I've finally got myself one of these awesome 6 cylinder Mercs. It's a 1978 1400 140HP. Anyways, I've been doing some searching tonight and I coming up with some conflicting results. I need a Trim Ram rebuild kit. One of my trim rams leak, so I want to do it right and rebuild them both at the same time. Problem is I keep finding different kits with different parts. Can anyone link me to the correct trim ram rebuild kit?
Thanks!
kazek
Re: 1978 Merc 1400 Trim Rams
Here is the Oring #'s for your motor.
Ref Part Num
Click for photo
(if available) Description Superceded
From Notes Factory
List Price Online
Order Price Quan
Used My
Order
Quan
64507A1 REPAIR KIT $60.41 $56.90 1
1 N.S.S. --"O" RING (1 1/2" X 1 5/8" X 1/16") (click here) 1 1
2 N.S.S. --"O" RING (3/4" X 15/16" X 1/8") (click here) 1 1
3 N.S.S. --"O" RING (5/8" X 3/4" X 1/16") (click here) 1 1
4 N.S.S. --"O" RING (1 1/4" X 1 7/16" X 1/16") (click here) 1 1
5 N.S.S. --"O" RING (7/32" X 11/32" X 1/16") (click here) 1 2
6 N.S.S. --"O" RING (1 5/8" X 1 13/16" X 1/8") (click here) 1 1
7 N.S.S. --"O" RING (1 5/16" X 1 1/2" X 1/8") (click here) 1 1
8 N.S.S. --"O" RING (1 7/8" X 2" X 1/8") (click here) 1 1
9 N.S.S. --"O" RING (1 3/4" X 1 15/16" X 1/8") (click here) 1 1
10 N.S.S. --SEAL, SLIPPER - PISTON (click here) 1 1
11 N.S.S. --PISTON, ROD - HEAVY DUTY (click here) 1 1
12 64505A1 RETAINER ASSEMBLY, PISTON This Part is No Longer Available $74.80 $69.10 1
13 N.S.S. --ROD, SCRAPER (click here) 1 1
14 N.S.S. --RETAINER, SCRAPER (click here) 1 1
Laddies
Banned
Here's a parts break down if you do not need the slipper rings the parts can be purchased a a hydraulic repair shop for about $10 a cyl. If you do need the slippers here's a better price. :: iShopMarine.com ::
sYnOnYx
Should I replace the slipper rings if I want this rebuild to last?
Chris1956
You need a special tool to replace the teflon piston seal.
If the motor leaks oil externally, it is the orings. If the motor trims down on it's own w/o an external leak, the teflon seals are likely bad. BTW - you can disassemble the cylinder leaving the piston installed in the cylinder (the cylinder is a steel liner), and replace all the orings, without disturbing the piston seal.
