1978 mercury 115 replacement trim fill screw
Elliomcmh
Hi, I have looked all over the Internet, and I can't seem to find a replacement trim fill screw for my 1978 mercury 115hp. Any ideas where I can find one? Thanks
Re: 1978 mercury 115 replacement trim fill screw
I would think that is a standard size screw. It is a bit short, but you should be able to find something to fit, maybe a longer bolt with a nut 1/2 way up?
Elliomcmh
Sorry, I don't have the P/n or s/n of my engine. I guess that would have been good information to write down before I posted my question. As soon as I get home, I can post that info. Part #2 is not the part I'm looking for, the part I'm looking for is the trim reservoir fill screw. My pump has an vertically mounted electric pump motor, two solenoids at the top, a square reservoir under the motor, a vent screw right next to the fill screw, then a manual trim knob, and four hydraulic lines below that. Sorry for the long reply, but thank you so much for your help.
Elliomcmh
Chris 1956- that's kind of what u was thinking. The original was a stubby, screw with a flat round head. And I believe it had an o-ring on it. Kind of like a lower unit fluid screw. Thanks so much for your help
Elliomcmh
Gerry, part #3 looks like the right part. I can't view the pump diagram, because I'm on my iPhone, but I might go ahead and order it anyway. Thank you for your help
Gee, the screw is probably 5/16" or maybe 3/8" and course thread, likely 1/2" long.
Elliomcmh
Thanks for your help guys, the one I ordered fit perfectly.
