I'm pretty sure the choke solenoid on the '78 Black Max 150 HP I recently bought is bad. I get 12 volts at the solenoid wire connection when the choke button on the control panel is pressed with the ignition in On / Run position, but the solenoid doesn't make any noise or click, so I'm pretty sure it's done for. My main question is how does this solenoid work, and what should be connected between the solenoid and choke plate? As seen in the picture below (sorry it's so dark), my solenoid doesn't have a linkage between it and the choke plate. I've found parts diagrams online, but none of them are very clear. If anyone has an actual picture that would be great! Otherwise a explanation of the linkage would be good. The solenoid has a hole in the end & when you look down it there's a cone looking piece with the pointy end up. I'm guessing that should pop out and engage the linkage?
