1978 Sea Nymph SS160 resto
Woodonglass
Re: 1978 Sea Nymph SS160 resto
The Rustoleum Topside Paint is an Oil Based Alkyd Paint. Almost the exact same formulation as All the mfgs of Oil Based Alkyd Paints. They ALL say not for water immersion. What they mean by that is "Constant" water immersion. If you trailer your boat and don't leave it in the water for more than 2-3 days at a time and wash it and maintain it on a regular basis it will hold up very well. I would have recommended you use the hardener with it, but it should still not blister and peel as long as the surface prep and primer was done properly. As with any paint job it's ALL about the prep. I have spoken with the Rustoleum Techs in Length about their Topside Paints and their Professional lines of paint and while they will not, in writing, admit that all this is factual, they have made statements to me that it is. The "Proof is in the Puddin" and the members here on the forum, Including me, that have used the products in this manner with excellent results KNOW that these alkyd paints hold up well on trailered boats. Enjoy your boat. She will need some touch ups but they are easy to do.;):joyous:
Watermann
Day 3 of the blitz and I have a few pics of my progress so far. Flotation foam is in from bow to stern and all of the bottom decking cut to fit but not screwed down yet.
View from the stern.
y4mgjzUCh7wvYhrfLf2KOJleItKBR4NjZfiWhIK1wVazfosyNarGaW5BI94nldu3IbsdGBp3w1L2hnrgWiylLkUvkdU9cdbhicLh3-X7KUFM-fCrixnhCV8y3RiSVuKq6YJQKt284grZJQpesefTHUr0Xw1S2WRmD_Jj_6FSchT9MiWm2TJJCghWqCqscmbppxkRTRJGQHA0vQQ3yDLGxF4BQ
Got the 2 lower deck pieces with 2 coats of Rusto deck armor.
y4mV1eDCW2n5va5okEbgoNTl0tM2PnLcr5wlcqcWEs3fbddR3-IxFOHShtlIgvZHyIp5YXYrzT63ktrMjktci6XNXDQN3awYMkTmNx1SAamfAJ1ryqk_avBBLIYTVrPlRxq4Zn1ObZiKlf0303OLKSDEy-Yd3G0Bbfc-YGv-3m3e7An7D0byfowlY6CgR5Zk3bMRREE9p4_8-_vKVwhUHhHTQ
Got started on the upper decking with the rear cut and fitted.
y4mYQdZJfeZz0ZWEmWqMNwZYPmjkuDiwZprQhptWZ89JV7ZFW7miLHtGw5hfZCiiusuqsqzCA53OcOVxk453uR78P8iHac4KEjpYwsqUE60T2q2O9a1OE_Z9d9EuF2APirFwkgs6Jkb5qGb3o1J-8D33V7WCupYGjmFNE7gusxS1AWE9ySZGxAuIe2AKzH8fVQn7WL2eriLHQQ4zo0VJA-Mbw
I got the helicoil put in the lower unit drain hole, which was a royal nail biting pain. Maybe later I will write up a tutorial on it with some pics for others in the future who run into the same problem.
Typical spring weather this week, yesterday it was pouring rain most of the day and today, it sprinkled, was cloudy, was sunny and the wind blew.
Watermann
Forgot one for SG...
y4mIVYZKrRE01st_0wbTXqdxyykaXgmoCDQLJsWPSToBtTmnjXUvS3eDa4niqdK-7Fhaa7fW2__vaUv-dRmQdbGy-WHfJqNUmTLq4wh2MHbmT6WTCTWKscA4V7VxTB4Ial0OQvi8c4BxhtovlMUBlvvhaoj6InPcwBlRTfSCbT1O853JJH0oX5YRmMCrc6yivBxcm2Llc0h0mvbTYOrfx2hHg
Funny how the colors of the decking changes with each picture I take inside and outside.
BonairII
Looking very nice! Some fine craftsmanship there.
Watermann
Thanks for the input wog, I have read your threads and see that you have walked the walk when it comes to painting boats. That means a lot to me, because I know some just talk and have never shot a boat with any kind of paint yet seem to know all about it. I stayed out of my garage paint booth for 24 hours after the paint job and left the heat on after the fumes cleared. It was difficult to say the least not to go stomping around inside stirring up dust. The only thing I wished I would have done differently now is that I could have done more to fill some dents in the hull but to tell you the truth I didn't really notice them until after the paint was on. The primer seems to hide them very well. I have to keep in mind that I'm restoring a 35 year old fishing boat that will see rough use in the future and it's not going to be a classy show boat.
Watermann
Of all the jobs I'm not looking forward to ever doing again, this has to rank right up there in the top 3 all time.
y4mBBSla-sVXv7SFQzzTmrg7EggvFX5iBY6zq-R6ELup-6ZCuv9O0xz7yVuoNAAVQQNnPkyVcJ_EWJFevYFHLOe0dV7gecI-WITCn3ohR2fe2ikRekHkm8eBRlcOpiFtSH2568fPNqlhe-LAqprmGeivnaB31W1vZU0U0mWcl5Lsue2tx8A4-qOQ0rNyMYBaw1-gryzd4kc0lkt3StDnEW88A
Measuring and cutting foam with my old skillsaw with the blade turned around backwards.
Streetgang
Hey what do you guys know, this new recruit is my resto buddy. Welcome aboard! Now we need to get you thinking about restoring that Smoker craft magnum of yours.
Well, well. The able bodied first assistant shows his first post. And posts a pic.
uforty3, I would be first in line to tag onto your resto if you go.
Nice job boys !
Streetgang
Thank you, perfect.
I noticed same thing and was going to make a smartass remark about having too much brain novacain but assuming that is your first mug doesnt apply.
It is interesting though.
Streetgang
Your after action thoughts please. I have been expirimenting with saber saw and a variety of blades. I know all the boys say if using blades in utility knife to bring a pocket full.
So reverse the blade is a twist would not have thought off but bottom line is would you cut it with skillsaw if had to do over?
Thank you.
train
Waterman, the paint looks great! Love the dark brown at the top. looks real good on the trailer
third times the charm
Nice job on the restro waterman:applause: Been catching up this morning over some coffee. :sleep: Wanted to post so I can follow the progress.:encouragement:
The paint job looks great, love that sand color. Been debating on that color for my Starcraft, or bone and Caribbean blue. Anyway good luck with project, looks like you will be able to enjoy the fruits of your labor this year. I have to say painting is going to my weakness, being I have never shot color on anything more then some closet doors,:friendly_wink:
Watermann
Thank you.
I experimented with all of the ways to cut the pink devil board except for a hot knife and then found the skill saw worked best for me. With the blade reversed there isn't as much saw dust from the teeth and the blade cuts the foam very well. I used only 3 of the 4x8 2" sheets and she was full up.
SigSaurP229
Great job watermann, its a good thing we aren't racing cause you are really kicking my butt even with a hernia surgery. She is looking great.
Watermann
Hey welcome aboard my SN thread TTTC. Rusto also has a oyster white that you should check out too if your wanting lighter than the sand beige. I will have to run over to your thread and check into your efforts. Painting is intimidating at first but there are some great words of wisdom here and maybe do some practice first by spraying primer or something else you don't care so much about. My target date for the splash is May 1st which would make it a 3 month whirlwind adventure.
Watermann
Last day of my 5 day resto blitz finds me with foam in, all the bottom decking screwed down, all the upper decking cut to fit including the hatch holes. I also have a surprise hatch that I will be getting worked out, see below...
y4m4Dl_zjoBIiQo7QZSMs1qc7y5dNQ0eKu0r7OxWMi8TQdFW6jbCyIxBafSXVxCAG0n2oj2cFjNOY_56ug2TPFOR2bTZ8q8T599eDueENyxZgL_wwM3jgOsanOsS64USGMEUX1oqmH78fnWldLXAY2V8L_rCfL6RSTWKFcMLyKHiOWOVkE1l2IKr7jPczNgXdVdqqjbIVjaCtvuffA8kVM9oQ
Always wanted a built in cooler for my boat, it got old loosing deck space to the cooler.
Watermann
Back deck isn't sitting in the boat but here's a view of the bottom and bow deck sitting in place.
y4mE_RZwdaJKkC7dv0d51TWtTDkxfccQFG6L1pBdbQ1fAcdyMYIjOIWExOfb41u2Eiq-lLfxjOR2zylOdTxp2V8GPE5LNlZJTR3YPAdxSNYiTSGk3agW0YZXEbPQ3Oab0Wm7-iVcfPWTbogzPrxAdDWgPjBHYj90Ej5JqVY9lJ5AINNhM_XEAYtgAI0roSvbzrWZxC5NkvOQ-Ng9pJmhA1Q1A
Love that built in cooler, yeah color choices aren't set yet. I got a quart of Caribbean blue and bone that I bought for my houseboat when i was on that kick. Just might use considering I already have it. Those decks are really coming along, my splash date might may 1 2014 if I'm lucky, lol. Not going to jink myself, did that 2 years ago
Pmccraney
Looking fantastic - you are moving fast! Tell me more about this "rusto deck guard" - Your non-skid surface looks great... (factory)
Watermann
Thanks for looking over my work guys and the positive feedback is always appreciated!
Hey TTTC check the paint you have, my Rusto said it has a shelf life of 2 years, not sure why it would go bad if sealed up but I would hate to find out the hard way after shooting it. Also my little SN took almost 3 quarts counting the brown stripe which was only about 8 ounces from the 32 oz can.
