1979 Chrysler 75hp powerhead model# 759H9A
kbh121956
Will a 1976 75hp powerhead bolt up to a 1979? The 1976 has 165 pounds of compression on all cylinders, the 79 has a bad number 3. Are the flywheels interchangeable between the two years? Thank you.
jerryjerry05
It should be a direct swap.
The flywheel might change? That depends on the ignition system.
If they use the same ignition it should change over.
