Hi all,
I bought this motor from a friend who had a problem with the lowest drain screw on the lower unit, now it's my problem. :facepalm:
He was able to easily remove the screw, drained and changed his lower gear oil, and was unable to get the screw back in. He instead used an epoxy that sealed the hole off to keep the oil inside, but I want a more permanent fix.
I am not sure how much extra metal is around that area to be able to retap a slightly larger hole so that a new slighlty larger screw would fit there. As of now, every lower gear oil change, I will have to chip off the epoxy (or maybe break it down with some acetone/paint thinner), change the gear oil, and then re-epoxy the bottom drain plug to keep the oil in the lower.
Anyone got any advice?
Thanks!!!
Thanks!!!
