1979 Evinrude 85HP v4 crossflow tune up "how"?
If piston to bore clearance is " large " then some crankcase compression can bleed off to the exhaust ports.
flyingscott
Before you take it apart do you have whats left of the new gasket set give us a pic. Usually there are extra parts because it fits many years.
bitsy4643
Have you taken into account at high speeds, to explain to the novice, what happens to back pressure as it seems there would be little or none. Common sense seems to be the prop and water prop wash would suck the exhaust from the engine. Is that not the case? What happens to your carb sync in that case and does it change sync tuning.from sitting still in water? Also, it has been suggested to tape prop exhaust to dulpicate back pressure while on ears. Is that an alternative? Thanks
