1979 Imperial
GT1000000
Re: 1979 Imperial
Crankin it out, bro...
couple more heavy duty, flying dust, poison powder induced, grinding hours and you'll be turnin the corner...
glnbnz
Re: 1979 Imperial
Yeah it looks like you are just grinding along lol...one of these days I will run out of excuses and will have to start grinding :eek:
bear_69cuda
Re: 1979 Imperial
Hey Gang,
Jackson Lee had surgery Tuesday, so I'm home with him chillin... He had a medial luxating patella, commonly called a trick knee. Anyhow surgery was 100% and now to keep a 1 yr old mix relaxed for 12 weeks of recovery! Good times!
Anyhow...
A few pics and more to come this afternoon...
My dust filter fan works awesome inside the boat while grinding!
BWMD = Bear's weapons of mass deconstruction....
Jackson Lee chillin!
boatnut74
Re: 1979 Imperial
That filter fan is a good idea. I'm sure it doesn't get it all but it probably makes a huge difference. Glad to hear Jackson is doing well :)
glnbnz
Re: 1979 Imperial
Yes glad to hear that Jackson is doing well!!
Looks like you got the grinding thing down pat.. :)
Woodonglass
Re: 1979 Imperial
Tip: Wrap a 3m Scotch Brite pad around the Grinder Air vents with a rubber band and you will increase their life 100%
Have you thought about the Vac Box idea and the grinder attachment? It works pretty well
bear_69cuda
Re: 1979 Imperial
Too bad the fan doesn't like it! 2nd box fan bites the dust!
Good times grinding! Note: Tinny boats.... I get it!
Great idea on scotch pad I'll try it. I thought about the vac-box, and regret not doing it... But I'm very close to the end of doom....
Woodonglass
Re: 1979 Imperial
Curious, Resin Discs or Flap Discs. Which is working for you best? What Grit R U Using?
bear_69cuda
Re: 1979 Imperial
Resin discs are the way! I'm using 28 grit. Flapper is to rough up areas to be glassed... 36 grit... I also find the cupped brush on my grinder to be helpful in removing old carpet glue, and foam residue...
Woodonglass
Re: 1979 Imperial
Yeah, that's what I use to. I use 24 grit from HF and they cut glass like butter. I've used the flappers from lowes 36# and UHHHMMM Not so Much!!!!
jasoutside
Re: 1979 Imperial
Jackson looks like he's milkin it a little there. Can't he pick up a tool and help ya out or is he claiming that oppoable thumb issue again:rolleyes:
(by the way, that job does not look fun)
GT1000000
Re: 1979 Imperial
Oh man, Nothing but good thoughts for Jackson Lee's full and complete recovery, glad to hear he's doing OK...And yeah, good luck on keeping him relaxed...for 12 weeks...:facepalm:...
Awesome job on the grind down, looks like you are 99.9% there...Fun,aint it???
glnbnz
Re: 1979 Imperial
I am reading that resin disks are the way to go. I have found some at Harbor Freight that are 5". Can you use them on a 4.5" grinder? I am assuming I would need a backing plate also correct??
Thanks
Woodonglass
Re: 1979 Imperial
HF has 4.5 too! I get em there all the time. Not sure if the 5" will work on a 4 1/2" grinder, I THINK they will. and Yep you need a backup pad.
JDA1975
Re: 1979 Imperial
Jackson looks comfy, realized he isn't my dogs brother! only 12 months old...old greybeard Rex is almost 5 now! Looks like you are moving right along, cant wait to see ya start some rebuilding!
bear_69cuda
Re: 1979 Imperial
Well I can't possibly take anymore DOOM today...
I'd say I'm at ~ 90% complete with my demo grinding... I'll spend a few hours on Saturday, then clean interior with MEK and Acetone... Remove a few pound of dust from the garage with leaf blower... Then flip hull for repair and gel-coat...
I did notice a few places will need reinforcement... I can see the gel from the inside... I may have gone a tad wild with the 24 grit.... :eek:
Progress!
Jon Sob
Master Chief Petty Officer
Re: 1979 Imperial
Only 10% to go and no more dusty doom ........ great job bear!
jbcurt00
Re: 1979 Imperial
I am not a big fan of better living through chemistry, but I can tell you that a little benedryl goes along way in keeping a good dog a down.........:facepalm: Our dog, Majic, twisted a 'knee' at a Las Vegas dog park. His hind leg was bandaged up like a chicken wing, and the vet suggested a whole benedryl 2X/day 1 am & 1 pm. He was 75+lbs & 3.5yrs old at that point. We went from 4-5 2hr+ dog park visits a week to none for 6wks. And only short walks for quite awhile after his leg was unwrapped. He'd have been bonkers when I got home from work w/out the benedryl. Check w/ JL's vet 1st, esp if he's on anti-inflammation/infection drugs.
And now back to our regularly scheduled program: Tear down & pending put back of a 1979 Imperial:
The work up to now looks really good. Nice job, & JL will certainly help you adjust to your new solo status. The yellow certainly gets my vote...... Looking forward to seeing you get the stringers back in & under a deck!:)
We'll send good thoughts JL's way til he's 100% again
