Baylinerchuck
- Jul 29, 2016
- 2,739
Lots of work ahead indeed....but a bad day of boat construction is better than a good day of work in my opinion. Something really relaxing about grinding fiberglass....:crazy:
I've always heard that Manatee's were built like tanks. Looks like it's true!Man that's a lot of stringers....
Ok guys i have questions. I understand the best way to install new deck is to encapsulate it in resin then put fiberglass mat over the top of the deck. Im looking for a lower budget way to do it. Ultimately i will do it if i can. Is there any ideas you guys have or have seen a cheaper but just as good alternative. Or if you could point me to store or website where i can get the chopped mat and resin for cheap
And how much resin do you think i need?. Also i would like to install foam in it as well. About how much foam do you think i need for this boat. 2 part expanding foam is expensive but id rather use it because it will sturdy up my boat. Any store to find that cheap? I dont mind doing the labor i mind dishing out 100s of dollars if i dont have to. I just dont want to buy all the stuff and find someplace where i could of gotten it for half the price. Thanks guys
So im wondering how much expanding foam i would need for my boat. Looking at the pictures the length is 10 ft the width between the stringers is about 10 inches and height of the stringers is about a foot for the two bilges in the middle and about 6 inches the outer bilges.
Also has anyone used it. Does is really provide ridgidity to the hull?
