1980 35hp Johnson --Wont Pee
1reddog1
I replaced the water pump impeller, and thermostat and the motor is not peeing? I pulled off the hose and it is clear no water coming from the engine. Any ideas on what to do next? I ran the motor for about 1 min to see if the thermostat needed to open but no pee
Tell tale could be plugged.-----Or put water in your test bucket 6" above the impeller.
Blow some air in it.----Or remove elbow at the motor to clean it out.
oldboat1
Agree with above. But check the top of the head to see if it's overheating (i.e. too hot to touch for a few seconds). An IR tester is a very good investment.
