timmeraw
- Jun 10, 2008
- 258
I picked up this 30 HP Chrysler (1980) that I am trying to get running right. Just finished fixing the lower unit after some diy'er had removed the shift pivot screw/pin. That was fun. Now I have it running/pumping/shifting etc but it is not running right. It's misfiring at idle something fierce (see video). I replaced the coils with ones I had around off an 89 force but that didn't resolve. Been trying to get the timing/sych correct. I found TDC and then located 30 degrees BTDC which I believe it is supposed to be. Marked then both on the flywheel and power head as you can see in this picture. Now when I run it with a timing light 30 degree mark is not lining up with the mark on the power head...OR....is the 30 degree supposed to show up where the TDC mark is on the powerhead? If so it is getting close to it but I believe is a bit late.
TDC is marked on flywheel to the right of the BTDC.. ignore the mark on the powerhead below the 30... I believe that the fire should be at 30 BTDC as in as it goes past TDC right?
Here is the video I took to show you the erratic idle and the timing results.
DSCN5490 - YouTube
Not really sure how to get everything set correctly. Like the stuff about the throttle cam just touching the roller at the mark...it is not quite touching etc.
I was just out playing with it again and manually advancing the throttle arm with one hand and running the timing light with the other and boy did I get zapped. I gotta get a water mister and see if I can see arching around the plug leads.
DSCN5490 - YouTube
