Re: 1980 cobia gulfstream
Home and on the cradles!!
Transport cost me 400$.
Cradles ( 2x6's and 2x4's) --100$.
Got it in the driveway by 8am. Spent 6 hours cleaning and inspecting.
The bad news:
1) Forward bulkhead that runs under console and aft wall of the cabin is just a shell of fiberglass that was so brittle my screwdriver went right thru it. Needs replacement which means the floor has to be removed.
2) I want to remove the twin aluminum fuel tanks that run amidships. The tag on one says it was built in 1979 --so Im assuming that its the original tank. This means the floor has to be removed --as far as I can see since the tanks are wider than the access hatch. There is foam surrounding the tank which is rock hard and shatters with a poke of the screwdriver.
3) The drain in the bottom of the transom is soft when I poke it with my screwdriver. I see major transom work in my future.
4) The cap has cracks all over it. Some are associated with a fixture screwed in--others places are just cracked. Nothing is a major problem --just a bit of grinding and then epoxy.
Overall I feel good about the boat. Nothing is really terminal that I can see.
*Edited* The crap brown color has to go. Im thinking blue or green metallic flake.
The bad news:
