Re: 1980 Mercury 40 hp Key switch?
Yes ! It looks like the crankshaft is off centre to the seal or is that the angle of the camera.The seperate black wire to the orange on the switchbox should be the tilt kill switch not the ground for the harness View attachment 180418 . The ground from the harness should be hookd to one of the switchbox hold down screws. View attachment 180417. The flywheel shows wear indicating rubbing against the flywheel that would blow the switchbox View attachment 180416 Bad bearing more than likely. Question Are any of the hold down screws that secure the stator striped? The stator must be securely held in place or as I described by your picture it is rubbing the flywheel and probably killing the switchboxes. It needs to be corrected or it will continue to blow more switchboxes. All you would have to do is change the upper end capand or bearing. That is fairly cheap on ebay. Note the upper bearing will come out with the upper end cap. I changed my upper bearing which also may be the cause of the rubbing marks on the flywheel. The seal will have to be redone as well JMO I hate to be the barrer of bad news but I,m 99% sure scraped one a week ago. EDIT I have to put the breaks on here there is obviously internal damage that lead to the condition that caused this situation of the flywheel rubbing the startor see next post
