1980 Sea Ray 210 CC - W/454?? question...
jpstude
Will an 898 even hook up to a 454? If it does, wouldn't it break down pretty easily due to the HP, or is an 898 heavy duty enough to handle a 454:confused:?
zbnutcase
Re: 1980 Sea Ray 210 CC - W/454?? question...
A 898 will break behind a big-block anything.
Don S
An 898 is an engine. 305 Chevy. If you are referring to the outdrive that says 898 on the decal, then it's the Mercruiser one drive. Old version of the Alpha I (aka pre Alpha)
They are good for 300 hp, and searay/Mercrusier did use the 454 with the alpha drives for a few years, until the Bravo was invented, or why the Bravo was invented.
If you run the boat reasonably, it should last. But will not stand up the full throttle starts and lots of heavy loads.
The gear ratio is also wrong, which makes it even harder on the one drive because you have so much more pitch in a 454 prop in order to keep the WOT rpm in the proper range. The 898 uses a 1.50, the 454 needs a 1.32 ratio.
frank246
Even worse, the 898 o/d has 1.65:1 gear ratio !
jpstude
:eek:Well, that answers some questions! LOL I guess my next option is re-powering with a 350, and probably assuming that the outdrive is toasted. Is there apossibility of switching to an Alpha-One without too much hacking?
As usual, you guys are the best! :)
Don S
What is on there now, and what are you actually trying to do.
jpstude
I keep hearing that 305's are junk so, I don't want that. The outdrive is "in a range of numbers" so, I don't exactly know what it is. My mistake was assuming the 898 was the outdrive itself. I just want her to be dependable and be able to scoot home if the weather goes South on me. Puget Sound isn't too dangerous but I still like to get out of a blow.
Ayuh,... If you want Dependability with a Big Block,... Go with a Bravo drive...
The drive you have, will support a 350, but little more...
jpstude
Thanks again, Bond-O! I'm going to go with the 350, for now. If i don't like it, I can always change it out to a Bravo later. As always - you guys are the best - Thanks J.P.:)
