jigngrub
- Mar 19, 2011
- 8,155
Re: 1980 starcraft SS restoraton
That really depends on what type of deck finish you're going to use, carpet, vinyl, etc. Stainless screws will be fine with carpet, if you go with vinyl I recommend rivets. I strongly suggest you fasten your decking down through the finish (carpet, vinyl), this way you can remove the decking without destroying your deck finish in case you ever need to do repairs below deck (leaks, livewell plumbing....). If you try to use screws on a vinyl finish the screws heads will twist the vinyl.
Epoxy resin is the way to go on the decking sealer, it only costs a little more than urethane varnish but is much stronger.
I have a 12 volt 55 lb. Motorguide Wireless trolling motor on my 17' deep V Tracker and love it! I can run the trolling from anywhere in the boat and I'm not a slave to a foot pedal on the bow. The variable speed really saves battery power too, I can use it for 2 days without recharging.
whats the best way to secure the plywood to the stringers and boat? i noticed it was mostly riveted before, i was thinking of using some stainless self tapping screws to secure it.
