Hi all
I have discovered that having just sold my previous boat due to the amount of structural work needed and the limited amounts of free time I have available, that I'm now sadly facing a similar but slightly smaller scale problem on my 'new' boat.
The boat I just got is an 18' Coastworker console boat:
I found damp in the transom to varying degrees, and am fairly sure now after investigation that this will need to be treated with a re-core rather than some attempt to treat the damp and then rebond the slightly delaminated layers of the transom.
Now I have never tackled a job like this before. I am savvy in matters of a mechanical nature, but not very experienced in glassing layup etc so this is daunting but doable for me.
This is the transom in question:
And inside (where you see the sealed, self draining deck of the boat):
The core still seems strong, and is dry in some areas but I don't entirely trust that it could be dried and treated successfully and last a long time, much as I would like to believe that's the case.
I already have some sheets of marine ply (12mm) that I can make new panels from, and about 1.5 gal (UK) of West Epoxy (105/206).
What I would like some input on to begin with is the matter of doing this by removing inside or outside skin?
I have seen lots of accounts of boats repaired either way during my last week or so of investigating this kind of job). It seems that many people see it as perfectly acceptable to cut the outer skin, whereas some people begin to foam at the mouth at the though of doing this!
Going from the inside would be difficult for me due to the bonded in sealed deck that I REALLY am reluctant to start hacking up. I have grave fears for just how well I might be capable of tidying all that back up if I did attack the transom from inside.
Now I started thinking about the physics of a hull/transom/outboard, and which parts of the transom would suffer the most stresses and have the most forces acting on them.
Presumably the biggest stress from an outboard is in a clockwise torque action (ie viewing the boat side on, bow at the left, stern at the right).
My rationale for this is twofold -
So from what I can gather the forces against the transom are predominantly going to be working to twist like so:
Now if that's the case, then surely a recore from outside is preferable in terms of strength?
I.e. you would want the best and least molested surface of the transom on the inside, since that is where the forces are 'pulling' at (towards the rear at the top), whereas on the outside face it's a compressive force against the transom (low down) that shouldn't matter as much if it's been subject to repair. The reason for this is that the torque against the transom would be low down where there is a very strong bond against the bottom of the hull/stringers etc.
Cosmetically/aesthetically I can see the inside being a much better option but I don't care about that, and in terms of strength, while I'm no physicist, the outside seems the better option.
Yet with all that said I know some people start to foam at the mouth at the prospect of someone cutting the outer skin like this. So why is that? Or do I have this figured out all wrong?
I'm not stating I will do it either way yet, but the outside seems more logical both from ease of access, and from strength points of view, but this is not based on experience!
I have got some supply of carbon cloth that I was going to use for other projects, so regardless of whether I recore from inside or outside, would it be prudent to utilise this strong material along joins etc, and where an overlap/fillet will take place - that sort of thing?
Appreciate tips on this sort of thing thanks.
Jim
- First that the weight of the engine would presumably exert force in this way constantly by virtue of its weight and the way it hangs (ie mostly behind the pivot tilt tube point and bracket), and
- Second, when accelerating/or when underway, the outboard is exerting both the force of its weight AND the thrust of the prop/leg pushing forward towards the hull.
Jim
