Re: 1980s Coastworker 180 transom core replacement questions/advice sought
Well, I decided no point wasting time and after getting the kids settled down in bed tonight I got busy with tape measure, marker pen, drill, and jigsaw.
I'll start by saying that the quality of this tub beneath the surface is surprising, but not in a good way.
I'll mention also right now that the people who make these boats now are not the same people who used to build them, so I'm in no way commenting on the brand or suggesting anything other than purely what I am currently finding in my own boat.
So....
The first cut I made was inside one of the rear storage lockers since they're directly above one of the deck support grid bits:
You can see a big crack there and I was able to grip that piece and waggle it around!!
Same on the opposite side, and the bracing piece was actually only still held in place by about 2cm of CSM that hadn't come apart yet.
Didn't take much effort at all to just pull the whole piece out!! So this was evidence that it really hadn't been secured/glassed in properly in the slightest.
Inside this piece there was a bit of foam, but not right through it. As I poked around there, it became apparent that the two main front to back 'rails' that the deck is bonded onto, are just hollow fibreglass section with no foam/wood etc inside, and very badly glassed in.
Most of the bits I had access to had big loose pieces of fibreglass that move around freely when you prod them. It's incredible, and I can only assume has always been like this, because a lot of this stuff doesn't appear to have torn, snapped or whatever.
Here's more examples of what I mean:
I've cut six holes out tonight - two in the rear lockers over broken brace bits, two inside the seat pod, and two on the open deck over the midships braces (also broken). Each hole is roughly about 12-15" by 8-10" or so and gives a lot of access to glass things up nice and strong, and to get dodgy bits out.
I'm certain I'll need to make more holes further forwards, and possibly to enlarge them in some places. Shame to spoil an unscathed deck but needs must, and I have plans for hiding the scars once she's fixed up...
Now this boat is what they describe as 'near unsinkable' and it all comes down to a load of encased buoyancy.
The space beneath the deck is more or less rammed with gallon containers but it's all flawed.
I pulled out a few like this:
Some without lids, and some with pinprick holes which had soaked up a small amount of water. Can only assume they have been holes by moving and being abraded by exposed deck fittings, or sharp bits of fibreglass etc since they're enclosed so they can't have been owner sabotaged really.
I've pulled out maybe 1/4 to 1/3 of the number under there by my reckoning:
Some of the deck has ply in it, other places don't.
It might sound bizarre, but I actually feel a whole lot happier about this now that I've chopped it up a bit.
I can see loads of crappiness where glass work has either come apart over the years, or just never been glassed down in the first place.
IMHO stuff like this just shouldn't come apart, or at least not nearly so much of it like this!!
Don't get me wrong, the deck is very firmly secured in place and it may have always been like this for the most part except for where there are actual cracks and broken bits (as opposed to just not glassed down), but I think it's incredible that it's like this, and am almost excited about the fact that I'll be making it a lot more strong & rigid than it ever was.
So....
