1981 120 mercruiser broken rocker arm
Dannysmyk
Hello all,
Been hitting it hard this summer trying to get out as much as i can but ran into some trouble the other day. Was cruising at about 3800RPM when all of the sudden the engine started to backfire terribly. Came to a stop and started to poke around when i removed the vale cover i noticed a broken rocker arm. I purchased a new one and plan to put it in in the next few days but im wondering could this be a freak accident or just the failure from another more serious issue. Also what is the "protocol" and what should i look for to see if something else caused this to happen.
Thanks, Dan
kenny nunez
I have had brand new engines break a rocker arm. Never had a problem after replacing them.
Make sure the stud is not partially pulled out. Use a straight edge or just eyeball the one that had the problem. Check the compression to make sure that a valve did not float and from a bent valve.
You have a 45 year old motor
Anything could have happened. Could be rust, a nick in the arm, binding
They are cheap stamped rockers
