Cut the plastic runners to fit my tank and life it off the bottom, gonna attach them to the tank with some Gflex 650 after I address a few spots with some pitting using the same epoxy. The plastic should be thick enough to provide the gap at the bottom crease off the hull but if not he got some thicker stuff I’ll have to use.
In regards to my fuel tank, the fill and vent necks are at the front of the tank pointing starboard. I was hoping I could mount the fill/vent cap on the port side to make it the same as my truck for ease of fueling. Has anyone else had a tank like this and made it work to the port side? I realize the fill hose is stiffer and I wasn’t sure if I can route it to the port gunnel practically. Not a huge deal if it’s starboard side but would like any input on someone with this same experience.
Pic is when I first cut the strips and before i addressed the pitting spots. I plan on using 4 on the bottom and 1 on each end where it’ll contact aluminum to hold in place.
