1982 GW, 24' Project (UPDATED W/PICS)
oops!
Re: 1982 GW, 24' Project (PICS UPDATED DAILY)
yeah....they allways say ...."i just used it.......
corrosion so bad it would not have used in a year !.....
looks good tho........the water is just around the corner !
LX Kid
Ensign
Today I installed the water pump and new carburetor. Started her up and she purred like a kitten!! When I turned off the engine gas came out the carb accelerator pump shaft hole and onto the manifold. Even thought it's a new carb I guess I'm going to have to go in and adjust the float level. Do they make a fuel cut off solenoid? Now the saga go on and on! The alternator was charging but was frozen in the bracket and unadjustable. I removed the whole starter w/bracket and the bearings are fried! Just decided to get new 105 amp alternator, ($84 shipped), cause it looked in such sad rusted shape. When I bought the boat I figured I'd have to spend about $1500-$2500 to get it up and going. So actually I'm not too disappointed with cost of project, just all the lies the seller had told me about how mechanicaly good shape the boat was in!
LX Kid
Ensign
Tilt/Trim sloenoid problem resolved. Thanks Don! Auto solenoids get their grounds from their mounts. Took grounds off "I" terminal and it works just fine. The "I" terminals are not used when useing automotive solenoids. Ron
LX Kid
Ensign
Re: 1982 GW, 24' Project (PICS UPDATED 9/14/08)
Started tackling the eletrical today. Got to find some reasonably priced DPDT switches. Got the engne exhaust fan going and my son started buffing out the hull. Just when I thought I was making some real headway I found a crack in the lower. Acris says that it is a cavity in the foot that is breaking out from trash and can be fixed.
LX Kid
Ensign
Re: 1982 GW, 24' Project (UPDATED 9/16/08)
Thanks once again "achris" for your advice and input to my problems. Today was busy day with the lower problem and now it's at the welding shop. Repairing crack and putting new skeg on for $135. Did'nt do much except work on getting the lower off and to the shop.
LX Kid
Ensign
Wow! In at noon and out at 6pm. I like that kind of service! I'll be sealing and painting it tomorrow. Ron
zach103
damnn. what was wrong with the skeg??
LX Kid
Ensign
It was chipped, back corner broken off and only half the size in length of the new one. Decided to get it done to protect the prop ($90). Ron
zach103
hmm .. i gotta look into that..
did it look like this??
LX Kid
Ensign
Yes it did except not quite as bad as yours. You really vulnerable to hits to your prop. Oh yeh, props are exspensive! Ron
zach103
i know i gotta get a new one.. its makin the hull vibrate for a couple seconds on acceleration.. how do they fix the skeg like that?
LX Kid
Ensign
The skeg is already made and they just cut off the bad portion and weld on and shape the new one so it looks like factory original skeg but longer. Are you sure your vibration is being caused by that? Is yours I/O or outboard and # cylinders and HP? What about your thrust washer on the shaft for end play when your first accelerate? Ron
zach103
its an 86 johnson 4cly 90hp. ob. we broke the drive shaft? last year. i can gun it and prop wouldnt spin.. so my dads buddy replaced it with a different lower end. (hes an ob guru and has the same ob) he said that the shaft running from the upper was fine when he replaced it and it only ran once since then. . he said its probably the prop. but im interested in what you think
LX Kid
Ensign
A a "novice" boater/repairman please don't take me tooooo seriously cause I'm just learning about boat engines myself. There is a lot of talent on this web site and they have helped me so many times. I read my repair manual and try to ask the right questions. Ron
FreeBeeTony
Gotta say I am very impressed by what you have done on this project in such a short amount of time!
Glad you took my advice to come over............
I look forward to seeing more and might do some of the same.
I initially had engine problems.........did some restoration..........replaced teak with starboard, painted cockpit, installed pulpit/windlass, etc.........
jcsercsa
looks great now LX Kid he does great work !! John
LX Kid
Ensign
Not very much got done yesterday. Only got the lower primered with Red Oxide paint and started working on rebuilding the front gas tank cover. Spent lot of time getting an understanding of how my I/O lubrication works and how to service it. Hope my new switches arrive today so that I can start rewireing the switch panel tomorrow. Only 4 days left on my "3-Week Project." Here's couple of pics. Ron
FreeBeeTony
Re: 1982 GW, 24' Project (UPDATED 9/17/08)
Hey LX...........what did you use for the blue fabric in the helm area and what did you cover the bottom of the bulkhead with?
LX Kid
Ensign
I bought indoor/outdoor carpet at Home Depot for .43 cents square foot. Used 3M spray adhesive, the heavy duty one $12, to attach to fiberglass and woodwork. The lower area is what they use to make new shower stall walls. I don't know what they call it but had to buy 4x8 sheet for $27.00 and used tin snips to cut it. Seems to work out really well. Don't forget to use caulk adhesive at the bottom. Ron
LX Kid
Ensign
PROJECT DAY #19 Feel like I'm moving at a snails pace now. Only got the lower foot painted and installed the new impellar. The temp was 95 degrees today, which isn't bad, it's the humidity that gets to me. Recieved the alternator and will install it and the lower foot tomorrow. Hope my new switches come tomorrow from Radio Shack to start making the new switch panel. 8 switches, 8 lights and 8 fuse holders. Ron
