1982 mercruiser 470
diogee2
I am looking to buy a boat that has a 470 in it, what are some spots I should check and things I should look for while checking it out. What kind of numbers should I be looking at for the compression check. I attatched a picture so if you see anyhting obviously wrong please let me know. Thanks Ahead of time, Jason
dry dock
Re: 1982 mercruiser 470
check other posts for 470 that will cover issues with the engine. cam seal antifreeze leak, charging system , heat exchanger change from 3' to 4'. ive have one since 06 seems to run good for me but a lot of people don't like them. learn to do all of your maint............it will be cheaper. good luck and welcome to i boats
Ayuh,... There's Nothing to Check,... Just DON'T Buy it....
