1982 Sylvan Bassboat project
GT1000000
Re: 1982 Sylvan Bassboat project
Hiya Craig,
Good luck on the Marathon!
Stoked to hear you got the rest of your supplies...now you can start fillin that hull with some structure...
You know the basics, pre-soak the wood with resin and add a layer of CSM...
Now there are a couple schools of thought on how best to attach the transom plate to the hull...
PB or 2-3 layers of resin soaked CSM...
From what I have read throughout the forum, both will work equally well with only one caveat...the CSM Layers requires that the hull face, where the plate attaches, be pretty fairly smooth and level acroos its entire contact surface to insure thorough contact between the parts, whereas with the PB, you just have to have enough in between the two parts, to fill any voids...
I attached mine using the PB, because of the above reason...the hull face was not perfectly level and I didn't feel like going through an entire process of filling and fairing, plus with the tabbing and laminating over the top, I think it came out "Tank Strong"...
The biggest suggestions I could give are to drill several holes in the hull, to allow some of the excess PB a place to escape and not possibly form any air bubbles.
Oh CARP! I just remembered, you have already painted your hull, so the idea of drilling into it is not so good...the other option, is to drill your OB mounting holes and the splashwell drain hole, use those as relief holes...
Make a bit more than you think you'll need, cause this is one time you don't want to run short...you can take a tip I read and have 2 or 3 batches of PB, pre-measured, but NOT pre-mixed...if you need it, you can have an assistant mix it up in about a minute, faster if you are using the drill motor method, and keep right on going...the stuff you don't mix up, can go right back in its container...
Application can be by trowel, which I fully intended to use, but couldn't remember for the life of me where I had put it...I have since found it and added it to my glassing tool arsenal...
The method I used...I call, the gloop...:facepalm:...pour it on, spread it out with a bondo spreader, to approximately 1/8-1/4 inch thick, slap the transom plate, give it a bit of a jiggle, kind of like setting a tile, and clamp, then spread out the PB that oozed out into the best possible fillet you can, under the rushed conditions you will probably be experiencing, then after several hectic and stressful minutes of this, you will have earned a break...if you will be continuing after this, then you can start getting your tabbing and lamination supplies prepped for the final installment of the transom...once the PB has kicked off, and it is hard, you may proceed...
If needed, do a quick grinding of any hard bumps, lumps, or straight up pokey glass strands...mix a small batch of PB to fill any spots you couldn't get to earlier, then you can do the tabbing and lamming...
You can, if properly prepared, and the clamps don't get in the way, do all of the above while it is still wet...but you literally should practice it both in your head and for real, with whoever will be assisting you...
Have Fun and I'll be looking forward to pictures of you actually participating in both Marathons, the running one and the transom one...:D
PS- Some very useful tips and reminders...
Double and triple check all your tools and supplies before mixing your first batch of resin...:rolleyes:
Cut about half the bristles off the chip brush to make it stiffer for dabbing airbubbles out
Keep a container with Acetone handy and some paper towels or rags...for quick clean up or dumping in reuseable tools for soaking and cleaning
Keep talcum powder handy for keeping the inevitable sticky tackiness at bay
Put on at least 2 or even 3 and 4 layers of latex gloves on, as they get mucked up, you just peel off the top layer, and use talcum powder when putting on each layer, makes them easier to get on over one another...
sphelps
I thought I read somewhere to use a 1/4 " notched trowel for the pb kinda like setting tile.. Put the clamps on where the pb just starts to ouzz out but not so tight as to squeeze all the pb out.
Good luck with all your things going on this weekend!
Woodonglass
Craig,
Good luck on the marathon. Splash WILL happen Sunday IF the Weatherman is NOT a Liar!!!!:eek: If you need/want to talk it thru PM me and I'll send you my Cell# and we'll discuss. If you don't have a bubble roller it will be a bit harder but prolly ok. Follow the drawings and make SURE that the edges have no voids. Coat it Heavy with resin and get the edges good. Mix the resin a little light on the MEKP so cure time will be a bit longer. This will let it soak into the wood better. Cut the CSM 3" oversize and "Tear" the edges so it will wrap over easier. 45 mins flip it and do the other side. Use a Short Nap 6" roller and "defuzz" by scraping it with a hacksaw blade and then duct tape it to clean the fuzz off. When the wood is tacky lay the CSM Roll it down with the roller then pour the resin on and roll it out. Just enuf to wet it out clear. Less is best. I like to start in the middle and work out to the edges. I always roll the edge and pick the roller up and return to the middle and roll out again. I think this helps with not getting air bubbles. But that might be just me. 2 hours and you'll be done. If you're using PB GT's correct use a 1'4 grout trowel and apply to the skin and the wood. I would drill a dozen 1/2" holes in the transom (not the skin) so the PB will ooze in and create somewhat of a mechanical bond as well and it help prevent air bubbles during clamping. Clamp hard enuf to get ooze out and then stop. Make sure those "WOG" clamps are adjusted to apply equal pressure. Do a Dry run first so you'll know what to expect.
craigweaver
wow, thanks guys! You are all too kind to take the time to give so much help. All very good tips and advice I fully expect to put into use as soon as I can get out of work!
bear_69cuda
Brutha Craig,
kickin butt man!
Trailer demo, and transom cut n' glued... Nice! You're gunna be rollin now!
Just checking in man....
craigweaver
Brutha Craig,
kickin butt man!
Thanks Brutha Bear!
Ok, weekend and mid-week update. Saturday after a lengthy consult with Woodsy, I prepped and practiced and prepped and practiced and ran out of time to do any glass work. dab nab it!!
Sunday, got up ran a little marathon :eek: had no energy to move the rest of the day... Hey! who's idea was that anyways?
Monday, couldn't hardly climb out of bed, called in to work for a vacation day. Monday afternoon, managed to get moving enough to make my first nervous attempt at laying some glass. It went ok but man that stuff is sticky, lol
Monday's results, back side of transom
Today, it was so nice and warm (65F @ 6pm) had to give it another go. Tonight I gave the front side of the transom a try and I think I'm getting the hang of it. The corners layed down easier than the last time.
Next up, this weekend we tab it in and start working on stringers. It feels like the projects starting to kick into high gear now.
GT1000000
Just gettin ready for the sack and saw you got some real good stuff done...
Way to go CW!!! That there looks like you knew what you were doin...Perfecto!!!
Glad to hear you survived the marathon, sort of...:rolleyes:
Now, get plenty of rest at work, so you can get a lot of boat work done this weekend...
Happy end of the week...:D
sphelps
Nice first glassing ! Did you tear the edges a little ? It helps on the corners .
craigweaver
NICE!!, craig. Looks waaaay better than my first try at it.
Thanks Jitterbug, I had a lot of good advice ahead of time from the others on this forum.
Thanks Gus, That's the plan. I'm feeling much better today :)
I learned to tear a bit more on the second side. I also found that if I pulled a little on it as I dabbed it with the chip brush it helped it lay down better on corners.
jbcurt00
Outstanding, you survived the marathon! And the day after.....
The glassing looks great!
Have a great end to the week, and let the PB, filleting & tabbing commence, post haste:)
Decker83
Good looking glass job. Get the transom in and your on your way.
varns
Nice work craig. just checked in and your kicking butt
Woodonglass
CW, I'd say you're gettin it!!! Tuggin and Tearin is what makes it happen.
craigweaver
Thanks JBC, I agree let the fun commence!
Thanks Decker, read below....
Thanks, varns! We're just trying to catch up to you.
Thanks Wood! it's your advice that has made this easier.
KDAVID1
Great to see you coming along--bet your happy
craigweaver
Ok, this weekend was a mixed bag. Friday was georgous weather but my son was busy at a band festival. Saturday we had a cold front come through. It was back into the 40's for a high. No glassin when it's that cold. We took advantage of the colder weather and did a brake job on my car and ran errands. Today was back into the 60's and beautiful. We started by rotatilling the garden up then headed in to play with our boat :)
We went throught the process a couple of times. I wanted to make sure my son knew exactly how we were doing this so we didn't waste time. We used our WOG clamps to clamp it all down then backed them off just enought to slide them off. We got all our stuff arranged and let the fun commence.
Here's a few pics from the week. I consulted Wood on transom install and was told that he and OOPS both had been told by the old timers that the right way to install a transom was as follows.
drill 12 or more holes in 3 rows across the transom.
I gotta say drilling holes in our perfect new transom was pretty hard to do, lol We went with 3 rows of 5 holes 1/2 inch in size. The whole theory as I was told is that if you drill the holes they give the PB a place to go and help keep air from getting trapped between the hull and the transom. The added benefit is that the holes being filled with PB create a mechanical bond through the transom like driving nails trough. This all made enough sense to me to give it a go.
Today we dry fitted the transom;
Cleaned up and wiped it all down with acetone;
Set the transom back from the stern so we could coat it with PB.
Then clamped it all down with WOG clamps.
We filled all the gabs around the transom with PB and fileted it. We're letting it cure tonight. I'm hoping tomorow evening it will be nice enough to tab it in and get a full sheet of 1708 on it. We also picked up enough plywood to do all the stringers and bulkheads.
We also video'd the install tonight. Hopefully we can edit down the 45 min video to a reasonable length in the next few days and I'll upload it for others to learn from.
I hope everyone had a fruitfull weekend of working on their boats.
GT1000000
Wow Craig, you and your son have done a textbook transom install, great Job!...now you're really gonna start building up some steam!
sphelps
OH yeah ! You guys can give yourself a good pat on the back with that install ! It should be rock solid when your done!
Hey is your son in the band at school? I was a section leader in high school with the trumpet and my son did the same thing. We both were in schools with bands like the movie Drum Line. It was some of the funnest times in my life!
Have a good week gentlemen!!
Woodonglass
One things for sure...With proper care and maintenance, Your Son's Son will be able to enjoy that boat cuz that transom will be around for Decades. Absolutely Perfect installation!!!!!
